Got a 2021 3.0L with just under 30k miles and recently started acting like it was misfiring or skipping while in gear and brakes on. Noticed it would happen while stopped or just starting to take off and would occur within a few miles of starting my trip and wouldn't matter if I had preheated the truck. Now, especially that the outside temp is in the single digits it's happening more. No codes, no check engine light. I had it in for an oil change and reported it then but of course the dealer couldn't reproduce the issue. Today it's been doing it more than normal and was able to get it on video... But still no codes. Once it's over 1k-1.5k RPMs it's clear and after I driver for at least 5 miles it won't do it until it cools back down.
 Have not found much on line about it nor other reports.. can't find anything disconnected, broken or damaged under the hood as far as vacuum lines, connections and even the air box assembly.
Any other reports of this?
I can't be the only one that's had this happen. Skips like it's miss firing or maybe an injector acting up. The frustrating part aside from no codes is it doesn't happen all the time even on the cold days.
8 hours ago, silveradosid said:
you should still get it scanned to see if there is any miss fires on any of the cylinders
Last time I reported it to the dealer they claimed there was no info when they scanned it.
Try pushing the onstar button when it's doing it and see if they can catch the code.
OnStar is a sore subject... But no service with them.
Got my hands on a code reader and plugged it in .... All clean and no codes and it did it as I left work for the day. It seems to definitely not happen after the engine reaches 185 degrees and up to operating temp. If it is happening and I can get the RPMs over 1,500 it clears out but once I let it get back to idle it will happen until the temp comes up. Another thing I noticed is that it typically idles at about 750. When it starts acting up and it's idling smooth it's more at 850-900.
So far the only other info I've been able to determine that this occured when the engine temp is about 185 or less and the ambient air temp is around 40 or less and the RPMs are slightly higher. Air\Fuel mixture or cold air intake issue possibly while the choke or choke mode is on??
If you have no codes, or past codes - Just drive it until it comes on. I don't have that issue though. When the windchill was -20F, around 0F I had the engine block heater plugged in for a few hours. Started right up. But never had any of the issues your describing. Same motor.
Yea it's been driving me nuts with no codes and we are now going on almost 3 months of it acting daily now. I have had it stall out on me a couple of times recently and the symptoms just keep getting more pronounced. Hopefully it Will throw a code or error soon!
We want to learn more and make sure we get the appropriate parties involved. Please send an email to [email protected] with your VIN, along with a history of your vehicle concerns. Please be sure to include "GMC Trucks Forum" in the subject line. By sending us a message, you consent to the information you provide being monitored and recorded by GM or those acting on GM’s behalf, subject to the GM Privacy Statement: https://www.gm.com/privacy-statement.
Email has been sent.
Well the mystery has been solved. It was found that the when the air filter was inspected at the last service, the hose was not connected to the air box correctly there was an air leak going by the mass airflow sensor. Couldn't see it from the front side of the engine.....
Edited by Santito
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,743 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
