Who do you recommend to have my truck tuned? I’ve used blackbear for my older trucks but they tell me they can’t tune the 8 speed transmission. I’d like to get both engine and transmission tuned. Truck is like new with only 24k on it and I purchased it new in 2018. I have a plug in AFM disabler but still use AFM on on long interstate trips. It’s always disabled around town though.
2018 GMC Sierra crew cab 6.5’ standard bed 4x4 max tow package 3:42 gearing 6.2L + 8L90.
Completely stock except for stock muffler and flapper removed. Replaced with magnaflow 14909. Stock intake removed and replaced with AFE Momentum HD.
https://afepower.com/afe-power-54-74104-momentum-gt-pro-5r-cold-air-intake-system
Or should I just leave it alone? It occasionally tows my enclosed 4k lb trailer and max I’ve towed with it is 6k lbs. truck is rated at 11,700 lbs.
Edited by 2018GMC
Pretty sure the only tuner than can tune the transmission is HP Tuners. So you'd have to learn how to tune to use that. I use HP Tuners but I've had it for 13 years now, so my experience is a lot more with it.
Or find a shop that can tune it using HP Tuners. It won't be cheap no matter which way you go. The cost of HP Tuners and the credits required to tune both will be a chunk of change and you need to have the TCM unlocked through HP Tuners to tune that.
Edited by CamGTP
I did a can-tune/handheld tune from Hypertech called the Spectrum. It does everything EXCEPT tune the transmission. It does allow you to mess with the TQ converter, but I really don't notice a difference on the tranny. The K2 transmissions are LAZY in down shifting. But I did notice a nice improvement on HP/TQ. The truck is quicker off the line and accelerates quickly for just a Corsa Catback exhaust on it. I got it on sale at Realtrucks.com during a weekend special for $200 and change. Basically same price as a Range. It also allowed me to adjust the speedometer to 130 mph and adjust it for my 22 inch tires.  I have noticed ever since Covid, HP Tuners has "raised" their prices considerably since I had my last brand new 2018 SLT 6.2L when I called them back then.  Hypertech was very good over the phone with any questions, and updated my Denali through email very quickly onto the tuner when I got it. Good Luck with your decision
I had Black Bear provide me a tune, and I also later had a local shop do an HP Tuners tune on a dyno. I learned a lot about tunes on the second, but the improvements to torque and horsepower were not significant enough to make much driving experience change. I currently have the HPTuner tune applied, but felt the Black Bear did a little better job with dialing in the "shift points" using what's available outside unlocking the transmission.
So, it depends if you have a local shop with dyno, and/or want to get deep into settings; or if you want more of a DIY "plug and play". I highly recommend Black Bear for the later. I have used them on 3 GM trucks/suvs, and no complaints. 200k+ miles combined easy with no troubles or dealer issues. Dealer does "flash back" and report it as an update when they have done work.
Edited by ftwhite
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,140 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
