Hoping someone on the forum has experience programming the BCM on a 2019+ Silverado High Country.
The truck was in a flood and it has a salvage title. The truck does run and drive with the original BCM, but there are 25 fault codes in the BCM. I have replaced and reprogrammed most of the modules in the truck, but the BCM is giving me a hard time.
I am using:
Clore PL6100 battery maintainer set to 13.4V.
CarDAQ-M J2534-1/2 pass through
Win11 laptop with ACDelco TDS software and a hard line LAN connection (Since the truck has a salvage title ACDelco will not provide TDS support)
In the TDS software there are three stages to programming the BCM. It successfully completes the first stage of the programming. In the second stage (odometer programming) the software prompts to turn the ignition on. At this point the push button start is not functional so I can't follow the instructions and complete the programming of the BCM. I have replaced and successfully reprogrammed the keyless entry module and I have the fob in the center console (fob override). I have tried replace/reprogram and reprogram the BCM in the TDS software. Not sure what to try next.
Has anyone seen this problem where the push button start is not functioning during the BCM programming? Is there another module that would prevent the push button start from functioning during the BCM programming?
Any advice or pointers from TDS/BCM experts would be greatly appreciated.
Edited by skitahoe
