Recently purchased a new to me 2022 Chevy Silverado 2500HD, Midnight Edition, 6.6L Duramax, L5P, with just over 20,000 miles. The 3-digit code sheet that is normally in the glove box is missing. The dealership did provide a list of options and I can see some of course but how can I go about getting either the build sheet or code listing so I know ALL the trucks options?
Pic of said truck…
The build sheet is often trashed by the dealer clean up. I have had 5 new trucks in the last 20 yrs and never seen the build sheet.  Its gone, can't get another as there only purpose was for plant use and not intended for the customer.
The dealer can provide a lit of all options, this is excerpt of what I got
Edited by Z45
Pic of said truck…
If you want the entire build, go to the dealer with your VIN.  Parts or Service, have them punch it into GM IVH and print you the full sheet like what @Z45 posted above.
The only catch to this above?  If your truck was ex Canadian market.  IVH will only have 1/2 of the RPO descriptions.  Parts can get the full descriptions from the GM Parts catalog and they can print the build from the catalog instead.
Glovebox SPID is no longer.  See reply below confirming what 64BAwagon stated.
13 minutes ago, 64BAwagon said:
I believe you can scan the sticker in the drivers door and it will show you all the codes. This takes place of the RPO code sticker in the glovebox
Correct.  QR replaced the glovebox SPID.  They are not complete anymore like they used to be however, it only contains about 70% of the full RPO codes for the build.
QR Code on Certification Label Offers More RPO Codes – TechLink
Edited by newdude
I always save my build order form so I have everything.
I couldnt for the life of me remember "QR" code... LOL
My order for my new one went in the system today and got accepted. Sounds like lead times are down because I was told end of April to first of May potentially. I made sure it got queued in Flint
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 520 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
