Well, here's the story
The SPEEDY
I sold it, but I sold it for parts after i totaled it. Made some pretty stupid decisions and rolled it over in a ditch. Had the typical it can't happen to me, I'm invincible teenage attatude. So that pretty much explains it all for now. I guess I'm hopeing someone will learn from my mistake.
So here are the pics of what was left.
BTW: I really don't want to hear the usual "thats what happens when stupid parents buy their kids cars they aren't mature enough to have", because I bought that car with my own money, and I was paying for the insurance too.
D@mn dude, glad you are OK. Looking at that car, it's hard to see how you made it out without serious injury.
Sorry to hear it though. :)
:thumbs:
I know it rolled at least 3 times. I didn't have a single broken bone, never lost constiusness (sp?), and only had to get about 8 stitches on the back of my head. The car stopped on it's top, and I just crawled out, realized it was still running and reached in to turn it off. All i can say is that seat belts work, can't say that firebird seats have the best seat belts (blet goes through the head rest, and the head rest came out of the seat when it rolled) but it did it's job.
After seeing the pics and reading your follow-up, I'm glad that stitches were the only thing you recieved in the way of injuries. Looks to me like someone was looking out for you. :thumbs:
And good luck with the future car, if you decide to get another "Fox Body". Hope it returns to you the same way....without the same ending.
Thanks guys, not really worried about getting another one right now, just glad to be here. Still have lots of stuff I have to take care of now before that can happen anyway. To tell you the truth it was a lesson I needed to learn, something I will never forget.
Glad you're ok. We all make bad judgement calls from time to time. It appears that the beams in the doors stayed put, but the roofline took most of the abuse. Makes sense for it rolling.
Glad you're OK. The wife and I were in a rollover back when
we were dating. We weren't scared till we got out and saw
the car.
They make new cars every day. God only made one of you. :thumbs:
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
    • It would be sold as a "kit", lights + auth/programming code.   You can resell the code to someone else, if they just buy the lights, either new or used, and they can then use the code to get them to work on their truck.
    • Apologies in advance, this is a long post, there's a lot to explain.   A friend had a 2010 Avalanche with a 5.3 (LMG) that blew the head gaskets (amount other problems). He gave me a donor motor out of a 2007 suburban (LC9). I got it all installed, and everything hooked up. Went to go start it, and it stumbled a bit at first and died a couple times, but after trying a few times it sounded like it was running very well. Went out to go get some coolant, and came back the next day.    Upon trying to start it, the truck will crank and fire normally and the RPMs will raise to around 1,200 or 1,500, sounding great, and then the RPMs will decrease and it will just die. Repeat that a dozen or two dozen times, and eventually it will fire and idle beautifully. As soon as you touch the throttle, it will start misfiring and sound like absolute trash. When you let off the throttle it will come down and hunt around shaking and misfiring like crazy. A message will come up on the dash saying reduced engine power.    It is throwing codes for a map sensor circuit voltage High, as well as MAF sensor low frequency. With key on engine off, the map sensor reads about 4.8 volts on the vout pin, which the PCM interprets as about 17.8 PSI, contrasted to the barometer which my scan tool tells me reads about 13.5 PSI. However, once the engine starts and is idling this reading drops to about 5-6 PSI at a stable idle, and varies significantly when the engine is misfiring/ hunting like I said before. I should note that I used the intake and MAP sensor from the LC9 engine. I changed the connector on the 2010 harness to The 2007 connector. The pinouts for the sensors were printed right on the top, and I triple-checked that I put the correct wire into the correct place.   On the other hand, the MAF sensor reads consistently 0.0 g/s regardless of State. I have pulled my hair out trying to figure out this last detail. I have tried three different sensors, (all of which should be good, one of which was new), I have verified all the wiring from the sensor going back to the PCM, and have verified that the readings at the PCM are the same readings as at the sensor itself. The intake air temperature sensor is also functioning as normal. I verified all the voltages and grounds etc, and everything is as it should be. I don't have an oscilloscope to verify, but I probed with my multimeter (Klein mm720) on frequency Mode, and it reads that on initial cranking, the maf is producing between 3000 and 7000 HZ, and as soon as the engine fires that falls off to below, 1000, and if the engine continues to run, it will produce somewhat erratic readings between 5 and 100-200 HZ. It does increase notably when the engine is revved despite the misfirings. As I said before, I have verified all of the wires going to the PCM, and I have tried multiple known good sensors. I've tested all the pins and voltages from the sensor and verified them against the manual that they are what they should be. I tested all the wiring for both ohms and voltage drop, and everything tested fine. Like I said I tested at the sensor as well as right at the PCM, everything checked out.   The only other thing of note at least I think is the fact that the engine originally in the truck had VVT, but the engine I put in, the lc9, does not have VVT. I modified the cam sensor plug to work. I reference the wiring diagrams and double-checked that I modified the harness correctly to adapt it. There is obviously a code for the VVT solenoid, but I don't think that's the cause of my problems, and this friend will probably have the PCM sent off to tune out the codes at some point.   I'm writing this for my bed so I don't recall the exact codes, but I'll update the post tomorrow morning with the exact codes. And ideas or feedback much appreciated.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
