Well after being a member here for 4.5 years I finally bought a Silverado.
2025 Custom 2.7 4x4 with the standard bed. I bought it April 28th and absolutely love this thing. Already did a bunch of truck stuff.
    Gkistler
    Gkistler
  • Who's Online   5 Members, 0 Anonymous, 716 Guests (See full list)
