Yeah, so just like my other 4 rams and Tacoma, another truck gets the rear window leak. Seems no brand is safe. Ram and GM are both using these garbage plastic rear window frames that crack super easy. Took about 2 hours to figure out how to remove the rear headliner, back spoiler and light assembly and clean the glass channel and seal it up good. Both GM and Ram want to just replace the entire rear back glass, but it will just crack again and leak again. Super annoying, but if you fix any truck with the rear window leak, you can fix any of them. 2 hours and $17 will fix it for good. Don't pay the dealer thousands to band aid it.
One tip, once you apply a few beads of silicone, run a paper towel and create a trough like dip in the channel, than apply one more bead and use a blower to push the sealant in more. It helps really seal up any cracks and also if new cracks appear, they can't leak.
I used this video and sealant to fix it (not my video, found on reddit)
video I found
window sealant used Need at least 2x
I’m glad my rear window doesn’t have a slider and no roof lights to leak. I’ve had rear sliders and never used them anyway.
10 hours ago, EXSlider400 said:
https://www.gm-trucks.com/forums/topic/255000-diy-sliding-window-leak-permanent-repair/#google_vignette
I did the repair above to a 2019 1500 and it lasted, but just got a 2025 2500… is this still an issue with the new trucks…I assume yes.
Don't know about the 25s, but if you have a back slider with a plastic frame, it will crack and leak. Not if, but when.
Silicone is junk for the exterior of your vehicle, regardless if its indicated to be for glass/ windshields. It'll eventually haze and start drying up. The better choice is urethane which is what is actually used for gluing glass in. You can get a tube large enough to glue the whole back glass for $20.
Urethane won't flow into the cracks were the water is getting in, if Urethane worked we wouldn't need to be fixing the back windows since that's what's already on there. You need silicone because it has some flex to it and wont crack.
Good silicone will last 15-20 years easy. Seems these trucks are sold off after 1-2 years. Flowable silicone is best for fixing water intrusion issues. It is after all what aquarium manufacturers use.
The rear window leak is not because of the bead of urethane thats used to install the glass. Its the plastic frame that cracks and leaks. Water then wicks along the inner channel of the sliding glass frame, and seeps in around the corner to the interior side. Thats why you see water dripping in the same spot of most of the trucks in the upper outboard corner of the window frame where the track ends.
Quote
It won't. The reason why the "fix" is silicone is because its the cheapest solution, which is always the case for warranties and the like. Its always that way otherwise the OEMs would fix it the right way and replace the glass; hence why many report repeated failures of the sealant, only for GM to cave and replace the glass anyway. Further, aquariums are not a car and they don't sit outside in the elements.
Edited by carkhz316
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 1,554 Guests (See full list)
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
