So, ever since i got my 2024 Sierra, i've been saving my GM Points from service for the GM Kicker subwoofer kit. I have about $550 credit right now. Recently on another forum, someone mentioned that they went with a Kicker 51PTRTP10, a box with a 10" passive sub and amp. It's not a direct bolt on so to speak, but i doesn't take up much more room under the seat. I have found sources online for a new one in box for $350. Does anyone here have experience with this subwoofer? Any better than the GM version? Installation would be roughly the same, power wire from the battery, and this one would tie into the BOSE amp behind the rear seat.
