2015 GMC Yukon XLT
It used to ride like a caddy! Now, at 145,000 miles, more like a log truck on rough roads. I can feel every defect in the road. I found that the front shocks were leaking so I replaced them with OEM. (They are not magnaride or anything special, just plan shocks) Didn't notice any bump 'rebound' even before changing the shocks and none now either. My question revolves around the bump 'jounce'(?) that is housed within the strut. To me, it looked a bit smashed. Do they normally look like that? Does the vehicle actually set on those while going down the road or just when you bottom out? Out on a smooth highway, everything is good. But, hit a road that maybe has some wear and tear on it and you feel it in the seat and steering wheel as well. I was kidding my wife about hitting some train crossings a bit 'hot' for my taste and I can't help but wonder if that somehow affected the ride. Any suggestions/ideas appreciated!
Thanks!
maybe post a pic of them?
I know on gmt800 trucks, the jounces on the front end were part of the suspension, and needed to be replaced when they wore out.  They were not bump stops.
@davester Thanks. As ignorance(?) may have it, I had to reassemble so my wife could use her truck. I didn't think to take a picture... Anyway, those jounces aren't expensive and while it's no fun to take that stuff apart, it's not too bad.
Do you know if the vehicle 'rides' on the jounces, or are they just there to absorb the harder bumps? I did feel a difference with the new shocks, for sure. Just the overall ride isn't what it was.
jalexa, just to rule out tires, you haven't by chance swapped out the factory rims and tires for larger diameter custom wheels with lower profile tires or gone from P rated tires to LT tires sometime in your Yukon's lifetime have you?
Sorry, IDK the details of your suspension setup, so I can't say one way or the other.
The full service manual at alldata.com would have the method to set the ride height to stock, and I know it varies (for my '04, was measure the height of some part, for my '12it was measure the angle between two parts of the suspension).
For the gmt800's, the jounce is just slightly compressed for stock height.
@garagerog Ya know, I was actually thinking about the tires the other day. While I've still got the stock wheels that came on it, it is about due for a tire replacement. They don't have much life left. Ya think them being worn about out would affect the ride that much? I haven't noticed it when it was time to change the tires before.
I doubt tread depth would make any measurable difference in ride quality. Just supposition on my part but I would almost think that older tires would ride better than new ones due to degradation in the tensile strength of the steel belts in radial tires, but by no means should someone put off buying new tires when the tread depth is questionable or age of the tires dictates.
Can you pay the stealer to give you a diagnostic.  That might let you focus on the right direction.
    DaleB
    DaleB
  • Who's Online   4 Members, 1 Anonymous, 1,503 Guests (See full list)
    • If there are updates/fixes you want, you could pay to have the updates applied by the dealer.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
