I, recently, filled the tank on my truck and it only went to 3/4.
I figured it was an anomaly so I went out the next day and tried to top it off - I managed to get another gallon and a half in it.
Still shows 3/4 on the gauge.
First time I've seen this.
Either my fuel sender is going bad or, maybe, I can check with my Autel MaxiSys.
I'm not a mechanic but I play one in my backyard and  I haven't stayed at a Holiday Inn express lately so ...
Can anyone with scanner skills guide me on how I can check for a bad fuel sender issue or do a re-calibration?
Y'all are awesome and I appreciate this place more than I can say.
So, what do y'all think?
Edited by MikeBMW
  • Sad 1
Oddly, I found a post, somewhere, just recently (I don't recall the post) but it mentioned holding down the trip odometer reset button and, then, turning on the key to reset the gauge.
Clearly, this truck has no trip odometer button.
So, I thought hmmm, a longshot, but lemme check it out.
So, key on, in auxiliary mode, I just went to the trip odometer on the digital screen, zeroed it out, held down the button, turned off the key, still pressing the initial steering wheel button, turned it back on (auxiliary mode) and the fuel gauge came back to normal.
I'm dumbfounded - any ideas?
It appears I'm not alone in this, just new to me ... maybe my inadvertent fix, above, can help others?
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 258 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
