I just finished up an NV3500 swap on my truck. Jumped the NSS and went for a cruise! She’s got a refreshed 5.3 with a nice streetable cam. Man does she scream!
However, on idle, she likes to “hunt” for return to stable rpm after slowing to a stop. Is this due to the ECM not being tuned to think it has a manual transmission? The truck was tuned with the cam when it had an auto, would that tune need to be scrapped in order to run right with the manual? First foray into tuning and I’m a little lost in the concepts.
I would like to add that the truck runs great while driving, it’s just when idling. It also likes to kill itself when turning at idle. I’m sure this is due to parasitic draw from the PS pump
Ideally yes, you need to flash the computer with a manual OS as a starting point. There are many tables that are different and of course there would be no settings for the 4L60e transmission that is now missing.
Sometimes you can do a segment swap with a same year 1999 4.8/5.3 Manual tune file. You swap the transmission segments but that might not do everything required. If you flashed it to a manual OS, then flashed back in most of the engine side changes from your current tune, it should run like normal with some minor tweaks needed.
Not having the 4L60e right now makes it tougher to tune but not the end of the world, just some things won't work exactly 100% correct. If you kept this OS, you need to disable every single transmission related DTC. The abuse mode for the transmission must be disabled, torque mngt for the transmission must be disabled. Is the systems tab, in the systems options, if there is a "1" in the brake tq mngt tab for GMT-800, that needs to be set to zero.
Probably going to need to adjust a lot with the idle settings. Base running airflow, throttle follower. Perhaps even the idle timing some to make it happy.
All of this is with HP Tuners is what I'm talking about. I assume that is what you'd be using for tuning. Always save your file before you make any major changes here, that way you have something to go back to and work from.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
