I have a 2018 Silverado with the l83.
When the truck is cold it doesn't have any tick at all and sounds like it should, but when the truck gets at operating temperature, it starts ticking on the passenger side. I checked with a stethoscope and the sound came from cylinder 4 and 8. Right now I'm using 5w30 and the truck has 127k miles, AFM disabled by obd2.
Here's a video of the ticking noise after the truck was driven for 30 minutes: https://youtube.com/shorts/jFvwP1aVL84?si=IB-Ry-4wQTKcqq9N
Are my lifters bad?
Sounds more like injector tick than lifter tick. The direct injectors make a ton of noise on these trucks.
Even if that was lifter tick, I wouldn't even care because to me I've heard so much worse and those engines ran just fine.
If you had a bi-directional scan tool you can test the injector theory pretty easy. Just turn off each injector one by one and see if the tick noise on that side goes mostly away.
I appreciate your opinion. The truck runs like a dream! I'll try what you've said and see if that's the root cause of the tick.
Check for spark plug wire arcing, exhaust leaks[broken manifold bolts] and maybe pull the valve cover and check for bad rocker bearings before diving in deep.
Thanks for giving your opinion, I already checked the spark plug wires and exhaust manifold bolts. As a last resort, I'll remove the valve cover and check for bad rockers. I really hope it is a noisy injector. I was planning in a future do a DOD/AFM/VVT delete, but not right now 😮‍💨
    DaleB
    DaleB
  • Who's Online   4 Members, 1 Anonymous, 1,503 Guests (See full list)
    • If there are updates/fixes you want, you could pay to have the updates applied by the dealer.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
