The AC in my 2018 LTZ went out. I hooked up a manifold gauge set and put the system under 30inHg of vacuum. Over the course of two hours it dropped to about 27inHg. It makes me think a seal on the compressor is bad. I am going to throw some 1234yf (as called for by info panel on fan cowling) that is dyed to verify.
When researching replacement compressors, I found GM Genuine 85656961; This is what GM Genuine's website reccomends based on my VIN. RockAuto lists that part number under GM Genuine 86798574, which does not exist on the GM Genuine site.
The listing on RockAuto says that it is R134a. My truck has the 1234yf sticker. I know MY2017/2018 was the transition years for 134a to 1234yf Are the two compressors compatible? I know that 134a and 1234yf do not mix and use different fittings.
Any help is appreciated.
Rock Auto listing https://www.rockauto.com/en/moreinfo.php?pk=14080089&cc=3437551&pt=6628&jsn=1000
GM Genuine https://parts.gmparts.com/product/gm-genuine-parts-air-conditioning-compressor-kit-85656961
85656961 and 86798574 are both correct.  85656961 is the current number, 86798574 is the previous number, so Rock Auto probably has some older stock is all.
Compressor services 2015-2018 so the type of freon won't matter.  Fits trucks that had either R134a or R1234yf.
Be careful just adding in freon.  You don't want to be in a position of it being overfilled.  The ideal thing would be to have a shop suck it down and recharge it with dye to the proper amount, then look for leaks.
My gut says your condenser is bad, which they always are on these 14-19 trucks.  Could also be one of the two hoses connecting to the compressor.
Hmm, I will check out the condenser as well. When I hooked up my gauges I had 0 psi on high and low side, and never smelt any Freon during the vacuuming down. My diagnostic tool was reading 5psi on the high side when it was around 80deg out. I'm pretty sure I had nothing in the lines to recover.
Before I buy any parts, I am going to charge with 1 can of 1234yf-uv (8oz) to find the leak for sure.
    • Real Truck handles the warranty via GM.  We don't submit a warranty claim with GM, we have to submit it with Real Truck with a specific email/phone number.  Real Truck determines if the issue is covered or not based on the issue and pictures submitted.
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
