2 hours ago, Hoginedgewood said:
Was looking at new trucks online, only the upper models advertise a 2 speed? Maybe I read it wrong.
Were you looking at the HD trucks on the GM website or the half tons as that makes all the difference. As far as I know there are only two options for the HD trucks and that is the standard 2 speed transfer case or the 2 speed transfer case that has the added 4 high auto feature and they put that transfer case by default into the LTZ and High Country although its optional in the LT and not sure if its available in the work trucks.
The half tons, that is where its been a total mess in my estimation for a few years now with most trucks below the top trim having the single speed transfer case as standard but with the option of having the two speed such as one would get by choosing the Z71 package, however then not being able to get the two speed transfer case with the towing package unless it was a higher trim truck AND had the 6.2 gas so one could combine the towing package gearing diffs with the two speed transfer case. Having said that if its a trail boss package then it gets the two speed transfer case but not necessarily able to get the tow package as it would depend on trim level and engine chosen. Believe me, people have bought the GM half tons assuming "of course it will have a two speed transfer case" only to find out after when they really pay attention to what they now own .... crap, there is NO low range !.
I don't believe Ford or Ram have gone that way yet with their half tons but like I say its been a few years now that GM has done this with the half tons.
Edited by Chuck FB
My last three 1/2 ton GMC SLE's had the Z71 package. All of them had the 2 speed transfer case and Auto 4WD. My AT4HD has all of the above standard. In order of use, I use Auto 4WD the most then 4High. I rarely use 4LOW but like having it anyways. My next truck will probably be another AT4HD.
Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).
I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
23 minutes ago, Another JR said:
4 low is really nice on steep boat ramps.
 Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
This is a 1/2 ton thing ONLY.  All HDs 2020-2026 have the two speed transfer case, with Autotrac as an option (still a 2 speed transfer case but gains Auto mode).
1/2 tons 2019-2026, regular 4x4s come with a single speed case (no 4LO!), and trucks with Z71 ordered, or all Trail Boss trucks come with the 2 speed case.  2 speed case is also an option on WT, and is also standard on High Country.
Edited by newdude
  • Thanks 1
I thought I was building a HD 3500 srw, maybe I was lost.
I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.
One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    overspeed
    overspeed
  • Who's Online   1 Member, 0 Anonymous, 322 Guests (See full list)
