I have a 91 GMC SIERRA 1500 4.3 liter. My dipstick broke. Can someone tell me how long is the oil dipstick. Local Part stores do not stock the oil dipstick. If someone can tell me the length. I can match up an aftermarket one. Thank you.
Did the dipstick itself break or did the tube it slides into?  The stick is easy, just measure the 2 broken pieces, the tube is trickier, install the new 1, change the oil adding the factory spec oil quantity and see where it shows on the stick. You may have to trim the tube with a tubing cutter to get the stick accurate.
