Recently I've been getting a message, "New Brake Pads Detected. Reset Brake Pad Life?", But I haven't had the pads replaced and the truck only has 28,000 miles. The Brake Pad Life shows Front 64% and Rear 79%. I select NO to resetting the brake pad life and the message goes away but comes back at the nest restart.
I stopped by the dealer and was told that it sounds like a software glitch that would require reprogramming. Even though I have the extended warranty, they tell me that reprogramming is not covered unless a module was actually bad and needed to be replaced. Simply reprogramming is not covered. So, they want $200.00 just to diagnose the problem. If it turns out no bad module, another charge on top of that to do the reprogramming. If the cause was an actual bad module, everything would be covered under the warranty.
Just wondering if anyone else has had this problem. Should this issue be covered under the warranty?
Thanks
Did you physically inspect the brake pads?  When my brakes went bad I got a few different messages, one of which was the same as you did, but none of them said, your brakes are bad (or need attention, or anything like that).  I actually took it to the dealer because I thought the system was bad.  Nope, just some highly worn brake pads.
Thanks for the info. I'm doing an oil change today or tomorrow, so I'll check them then.
if the brakes are good and you keep an eye on them, just disable the stupid thing and call it a day. You can pick each set and disable it in the menu on the dash just to see if it stops the annoying nagging prompt.
Not in my 2021. It's either on or off. There is no selecting front or rear. My scanner says something like implausible value for the rear monitor. I just disabled monitoring and keep driving it. There's physical metal squealer tabs on the pads for a reason. That's how people always knew when to change the brake pads or ignore them until the vehicle wouldn't stop anymore!
Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 582 Guests (See full list)
