Future GM powerplants and vehicles
Chris97K1500
This may be old news, maybe not. Today on TV, a GM future vehicle section was talked about, can't remember what show. In it they mentioned a V10 or V12 Engine to be in Cadillac's future high performance V series Escalade. and a 405hp GTO in a year, due to a higher compression ratio than in the current LS1. A GM rep. also mentioned "many" new powerplants to be introduced over the next few years. Wonder what is true and what is not? Chris
No, it's the LS2.
If you go to www.LS1GTO.com and do a search on the LS2, there is a poster on the board who works for Holden in Australia who was test running a left hand drive setup GTO with an LS2 under the hood. They were testing the LS2 down under on purpose...to keep out of sight of the media. Something they (GM) had a hard time doing here stateside because of nosey camera's (if you follow me).
Rumor was originally that the '05 GTO with the LS2 may actually hit the streets before the C6 did as it was already being tested down under, away from that prying American media. But I don't think GM would let that happen.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,389 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
