Help with plugs for 5.3L and other stuff
Went to the local Autozone to get some goodies this past weekend and was going to get some new plugs (have waited way too long to replace them) anyway, the guy behind the counter said the OEM replacements from AC Delco were platinums and cost about $5-$6 a piece. Has anyone else heard of this? I was hoping a plug changeout would only cost about $20, but it seems that this is not the case.
Also, did the throttle body cleaning this weekend as well, Yeah no more sticky throttle. I only cleaned the outside of the flap and the seating area on the body itself. There was much more sticky gunk inside the body and on the back side of the flap. Do I need to get this as well.
What brake pads are recommended?
Thanks,
the platinum plugs do cost more - they are supposed to last longer than the copper kind. i put some regular copper NGK (TR55's maybe, its been a while so i cant remember for sure). they are quite a bit less expensive, but I only plan on leaving them in for 30k or so.
i havent done the tb cleaning yet - that will be a spring time project for me.
i went with the oem brake pads. the original rear pads lasted over 80k and the original front pads are still going at 95k. i cant complain about that kind of mileage out of brake pads!
the platinums will cost more i just changed my plugs today after 95000KM and the old ones were alright but a big improvement on the smoothness of the engine. I put in NGK G-Powers they were 6.50CDN a pair, I wanted the Iridiums but they were 10bucks a peice. but I went to my dealer and to the "Parts Counter" and for the OEM plugs it was 16dollars EACH :troll: I will just change these more often.
And yes you should clean the rest of the intake behind the butterfly, run a search here and there should be more info, also if you do not already have one get a manual.
:loser:
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
