whats wrong with my engine?
engine making odd sound. Kind of an exhaust sound like a bad cyl or something. dissapears over 2500 rpm to my ear. worse when cold.
new wires, dist cap, rotor, compression good, manifold pressure good. Not exhaust leak. Is this bad valve spring, or lifter, or something? 106K, mobil 1 5w30 always.
Oh yeah, only does it accelerating under load. wont do it if rev engine in neutral or park. Help. Hoping its something I can fix myself. No metallic tapping or anything like really.
sounds like an exhaust leak
try reving the engine up in drive with foot on the brake so the
truck doesn't move. for some reson most exhast leaks
are only noticable under load.
Pre ignition KNOCK maybe :thumbs: ....Check the base timing,if its to far advance it'l sound like marbles in th engine...ALSO check the exhaust flanges at the manifolds (as chevroletmb said) or take a good look at the flange area,any black marks are a dead giveaway of a leak
If it is an exhast leak it would be worst cold in the morns. Try this: Start the truck with the hood up in the morn then run around to underhood then rev it up by the throttle body and listen for the leak. This is the best way for as the engine heats up and expands then leak will become less prominant. If still not sure then get a helper and have them partially plug the exhaust with a rag and then listen for then leak. Ping usually gets worst as then engine heats up so I doubt that is your issue from your story. Good luck. (Oh and by the way, chev 350's are prone to cracking manifolds so don't be amazed if there is no evident leak at the flange. If you hear a leak and can't narrow it down then remove the manifold and check the underside for cracks. Mainly between the ports.)
If I'm not mistaken, the timing is adjusted on the fly by the computer...So messing with it is probably not a good idea in my opinion.
I had an anti-knock sensor go bad in my 92 (5.7 TBI) and it would detonate, ping, rattle, you name it if I got on it. I was thinking dead cylinder, cap/rotor/timing/etc, and was getting ready to pull the motor when a buddy with a code reader figured it out in about 5 minutes flat. I think I paid less than $5 for that part (salvage).
Is it throwing an SES light?
No, TBI's must be timed at zero degrees with the advance off. The 96 and up vortec are computer controlled.
Ill check again for exhaust leaks, restricting it sounds like an idea. Ive tried a stethoscope on manifold at idle and revving engine in park and dont hear anything abnormal. I thought I would hear something that way.
I checked base timing, its on 0. finding the connector was a pain , manual said it was in engine compartment, it was inside truck under glove box.
After sitting for a few weeks it ran really bad, undrivable actually. but I put in B12 chemtool and it cleared up and runs fine now, except for this issue. I figured that was a stuck injector. This sound has been going on since way before that happened so I think its unrelated.
I had a 92 that aftyer I put headers on I thoght had an exhaust leak. Would only be heard under the same circumstances you describe. Ended up being a noise from #7 cylinder ringing in the pipe. The way I found it was a really long 3/8 extension. One end on the pipe the other next to my ear. As soon as I did that I heard it right away. My guess is it is a valve leaking alittle. Was like that 2 years before I sold it and they guy who bought it is still running it--over 200k on it now.
sound seems to come from passenger side of engine
went out with engine cold and does make loud sound momentarily when revving exhaust with hood up, from passenger side.
On passenger side there is a metal shield around exhaust manifold, that a intake hose goes to to heat up some air on cold starts apparently, there is a thermostatic valve in the inlet duct for this. the shield seems to be riveted to the manifold, doesnt look removable.
underneath this shield ONLY my manifold is black, rest of it is pretty rust color. Im going to guess that the paint didnt just weather better under there. I may have a leak there. Is this a common place for a manifold to crack? can I remove the metal shield temporarily to check without destroying it? come to think of it , the last time I changed air filter, it looked "sooty" and not just dirty.
Don't know how common it is :thumbs: But that sounds like that could be it.
I'm not sure about that either :cool:
If you're lucky,maybe the bolts loosened a little...you can try to re-torque the exh. manifold bolts to spec.'s when the engine is COLD
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
