P 1345 engine code on crate motor
Hi All,
Can anyone tell me what a P1345 engine code is, and what could cause it/how to fix it?
Actually the code is P1345 Crankshaft Position [CKP] Camshaft Position [CMP] Correlation.
Please? Any help would be extremely appreciated.
The code came up as soon as a new crate motor was installed in my 98 Burb.
Thanks
Howard
The 2 of them together means your timing is off.
The timing on vortecs has to be done with the Tech 2 scan tool, not a light.
Thank's for the reply coolzr2. I just spoke to the dealer and they say they've tried that. Apparently, if they set it to where it's supposed to be at, it runs like a dog???
Any more options?
Thanks again
Howard
Any more options?
Thanks again
Howard
Then it must not be a stock motor.
If it is not stock, then you have to run the timing off to get it to run right with the non stock cam.
Thank's coolzr2.
How can I check as to whether or not the motor is stock?
I don't mind if it's an upgrade, but I don't want to be going backwards.
Best wishes
Howard
By the way, you are being an incredibly great help. The dealer has no idea what to do.
Thank's coolzr2.
Best wishes
Howard
Was it a goodwrench replacement motor?
    ballencd
    ballencd
  • Who's Online   1 Member, 0 Anonymous, 454 Guests (See full list)
