am i HEAVY duty ???
i have a 95 gmc k2500 suburban 4x4 7.4l 454 4l80E.
i checked the rpo's in the glove box...
and i have:
heavy duty front and rear springs
heavy duty suspension
heavy duty transfer case
heavy duty transmision cooling system
heavy duty alternater
the 10 inch rear diff
4.10 gears
what makes a truck "heavy duty" according to Chevy/GMC :loser:
when i look up parts at autozone my truck falls under light/standard duty NOT Heavy Duty.
any and all replys appreciated :loser:
[email protected]
Any truck with a GVW 8600 LBS or over is a heavy duty. Above 8600 has no gas mileage requirments. In your case its easy to check because 454 ci does not fall in the light duty class. :loser:
GM makes a truck model called HD or Heavy Duty. It's a 2500 or 3500 series truck. Your Suburban is a heavy duty (generic) vehicle. It's just not the GM Heavy Duty (HD) truck.
that's interesting. I guess with a 8700lb rating my half ton C3 is considered "Heavy Duty"?
I dont know what C3 stands for but ay Chevy/GMC truck that has 6.0 L engine is HD or a gas guzzler and falls in the HD group. :loser:
So my 2001 Suburban 2500 is really a 2500HD?
No.
For many years, GM made 2500 pickups with either 7200 or 8600 lb GVWRs. They were referred to as "light duty" and "heavy duty" respectively. However, there is no exterior badging to differentiate. Depending upon the year, you could usually tell because the light had 6 lug nut hubs and the heavy had 8 lug nuts. The frame, suspension, brakes and other components were also heavier duty on the 8600 lb version.
Now - none of this has anything to do with the "2500HD" designation now found on GM pickups. The 2500HD's actually have similar GVWR to the old-body-style 1 ton models (3500's). GM just likes to confuse everybody. Initially, the new-body-style pickups also had "light duty" and "heavy duty" 2500s (not 2500HDs) in 99 and 00 only I believe with the heavy having the same old 8600 lb GVWR.
The Suburban 2500 has an 8600 lb GVWR, so it is like the old style "heavy duty" pickup designation but it is not a "2500HD".
As a matter of fact, for the body style prior to 2001 - the Suburban 1500 had a GVWR closer to the old pickup style "light duty" 2500 designation. The 2500 has only been 8600 lb GVWR for many years back.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
