C/K Grille Changes
I have a 94 gmc c1500 with the sealed beam work truck grille. I have searched around a little and did not find this, but can the quad light assemblies and grille be bolted in or are there bracket problems? Thanks for your help.
I don't believe this change can be made easily. I think its possible, but very expensive. Maybe talk with your local body shop..
Actually it is really easy to do. The core supports are the same. Your emblem is the same.
You will need:
Composite headlight harness from 90-94 truck
Composite style grille from 94-98
Composite Headlights from 90-98
94-98 GMC composite corner markers
94-98 park lamps (don't get 88-93 lamps, they are different even though people will tell you they are the same)
grill-to-bumper filler panel from composite 94-98
The swap can be done in less than an hour.
