just today i converted a 80 205 transfer case into a yoke the original was a slip yoke my truck is a 75 chevy K-10 and the original t-case was a 203 part-time now my trouble is i dont have a long rear driveshaft to fit my 205 t-case so my question is would a Ford Rear driveshaft fit into my truck or cant be done :wtf:
Heck,almost anything can be done w/nuf money$$$$
I don't know about the Ford shaft,but you should be able to have a new driveshaft made by any compitent driveline shop.....just make sure that you put a slip joint on the shaft or it'l snap on the 1st bump you drive over.....
My 75 Chevy has a small block 350 thats mated to a TH350 but i would like to put a 400 engine in it would there be any difference in the heads and exhausts if i were to do that
My tranny 350 was rebuilt 4 yrs ago including the motor but i have a problem with my passing gear at first i thought it was the distributer but it wasnt could it be the Detent cable, when i looked at it it seemed alright but i dont know, my 79 K-15 the passing gear works good i dont know about this one though
A small block Chevy is a small block Chevy...350 and 400 r the same except 4 bore & stroke (internal measurements) all external dimensions r the same,heads r the same on the outside..............as far as the detent cable ...Have you tried adjusting it?
On top of the cable housing,where it goes through the mounting bracket,there is a button(kinda looks like a 1/2 circle) press down on the button to release the casing and pull back on the casing behind the bracket towards the firewall as far as you can....then w/the engine OFF...and using your HAND, open the throttle on the carb. till it stops...while you r doing this you should hear the detent cable click while its adjusting itself...then take er 4 a ride and c if that helped
  • 3 weeks later...
    overspeed
    overspeed
  • Who's Online   4 Members, 0 Anonymous, 981 Guests (See full list)
