Stoked!!!!
Ok this is something I've always wanted to do but for one reason or another I never did it. (Usually the reason was money :rolleyes: ) So next week I'm getting a FabTech 6" lift installed on my truck. Will be adding BFG TA KO 315/75/R16 mounted on Axis Sport Regulator Wheels.
These wheels are really cool and I always liked the bead lock look. Here is a link to the wheels Axis Sport Regulator, althought this is not the place I got them. (happened to find a picture here)
I have wanted a set up like that for quite some time, but the wife STRONGLY veto's that idea. She has other places she thinks money should go.
She used to understand these things, but when you get married, understanding for trucks gets lost somewhere! :rolleyes::chevy:
I know exactly what you mean. That is why I dumped mine..... :rolleyes::chevy::)
No longer a dead lock on the voting. Now there is only one vote to count but sometimes I can't even get that straight. :lol:
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
