fuel pump bad?
over the past 6 months or so I have twice had a problem with my engine "chugging". It happens when the fuel guage is about 1/4 full and especially on hot days and after I have been driving a long time (road trip). It's a 99 silverado and it has that whislte noise coming from the underneath or where the bed and cab connect. I've heard a '98 tahoe and countless suburbans make this whistle. some guy at a garage told me it was my fuel pump. any idears? :rolleyes:
thanks
Have you ever had the fuel filter replaced? A clogged filter will cause this also...It may be worth trying B4 condemming the pump
I wouldn't be too concerned about the whine. My 02 has done it since I bought it. Neighbors 01 does it as well. Both of them are nearing 60k miles.
You might have a water slug in tank too. GM fuel pumps on modern cars are in the fuel tanks and are pretty reliable. My 89 burb still has the orignal one (good thing too as I would hate to drop the shield and that 40 gal tank to change it! )
sure enough it was the fuel filter. The guy at the garage was in shock. factory fuel filter on a '99 Silverado, with 130, that's right One Hundred and Thirty THOUSAND miles on it. I love that girl. thanks a bunch yall. Everything runs better now!
I am having a similar issue with my truck. 2000 Silverado 1500 4X4. In the following scenario:
Going up a slight incline , at 30-35 MPH, the engine sort of has a timing issue, you can see the RPM gauge increase and decrease. Is this similar to your problem? My cousin thinks it might be the computer going haywire because it doesnt happen in any other conditions.
Also I have had to replace the power steering pump and the Ubolts. What is up with that?
Your tranny might be trying to lock/unlock and not make up it mind too and cause the RPM flux. I suspect tranny here more than a ECM glitch with engine.
Is there a cheap fix or do you think over time my transmission will just go? How serious of an issue do you think this is and should I take it to the shop to have them look at it? :thumbs:
:cheers:
Does it act the same whether in Drive or OD position? If it is the tranny hunting, it most likey will through out its life. It is more of an annoyance than anything as long as it does not do it under load.
over the past 6 months or so I have twice had a problem with my engine "chugging".  It happens when the fuel guage is about 1/4 full and especially on hot days and after I have been driving a long time (road trip).  It's a 99 silverado and it has that whislte noise coming from the underneath or where the bed and cab connect.  I've heard a '98 tahoe and countless suburbans make this whistle.  some guy at a garage told me it was my fuel pump.  any idears?  :thumbs:
thanks
This one could be the gas in the tank starting to "boil" so to speak or there could be a water slug in tank too that makes itself more known under those conditions. If it was the fuel pump, it would most likey do it full tank or 1/4.
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
