Question on Amp/Subwoofer/Power in GMC Envoy
How's it going folks? Nice forum you got here. I guess I can participate since I'm now a proud GMC owner ;)
Lots of good info here :D
Now I read a bunch of posts on alternaters/amps/power etc. and it seems like I'm ok. But I'm hoping to get some more specific comments/experience.
I have a 2002 GMC Envoy 4x4 6 cyl. It's fully loaded with pretty much every available option. I don't plan on doing more than what I already have.
I had an alarm installed. A 2 way Viper 791xv... I also had them install my old Amp/subwoofer box to the stock Bose stereo system. I used to have it in older Honda Accord and never had any problems.
The amp is a Rockford 800a2 and the box is a custom built sealed box with 2 12" Rockford DVCs. I think the amp puts out 1052 watts. But I could be mistaken. I can't find the manual and can't find any info on the Rockford website.
I also have a cap, a 1 farad cap.
It sounds really good, much better than when it was in the honda (probably more power and the open space).
So far I havent had any problems, no dimming. And like I said, that amp/box and alarm are the only devices that aren't stock.
Will this be a problem now or in the future? Meaning is this too much of a strain on the stock alt./battery. The installer recommended a Dry cell battery which is $179-$200. If it's worht it I don't mind paying the money...
Click here to see what I have installed.
I'm running a bit higher wattage than you with a 1 farad cap on a stock charging system as well.
It's been in there longer than a year without a single problem with alt, or battery. I'm just going to wait until one of them craps the bed to replace them.
the alarm should have little/no effect on the electrical system. they dont drain enough power to matter really, unless you're battery is dying.
but as for the 1000 watts of power, it'll give you a problem sooner or later. it's inevitable. a drycell would help, as would upgrading your charging system wires. the cap is going to help matters a little, but if you want to really see a difference add a 2nd battery to the mix. that puts less of a strain on your charging system than trying to keep that one big battery charged :D
or you could do like i do. just go with it and just have some extra money to replace what breaks. i ran almost 2000 watts rms in my fiance's grand am for a little over a year without a problem on her stock battery and altenator. (i had a 2nd battery with a 1 farad cap) but when the altenator went the battery did too, so it was a smooth $200 to replace the battery and put a higher amp altenator on there.
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
