I am looking at a couple of differrent trucks and wondering what kind of fuel mileage to expect, on a 2500 hd regular cab 4x4. The Duramax has impress me the most, but with the truck over the 8800 lbs no printout is available on fuel mileage. Also a friend said I should be concern about the aluminum heads, since iron and aluminum cools at a differrent rate. Any help and information would really help. Thanks :cool:
Don't listen to anyone who says to watch out for the aluminum heads. Ford and Dodge dealers made up this rumor a long time ago. I heard it from all of them when I looked for a diesel truck. I have yet to hear of ANY incident involving the aluminum heads.
I get between 17 and 19 mpg with a CC 4x4. I would expect at least that.
Hi -
If you haven't already, go to The Diesel Place and read up. Very little talk about the aluminum heads.
I'm getting an average of 15 city and anywhere between 18-19 highway while running around empty. I can live with that seeing that my truck is lifted and has 305's
HERES MY 2 CENTS I HAVE A FREIND THAT WORKS AT ROUSE
FOR PRODUST RD WHEN THE DURAMAX FIRST CAME ON THEY
HAD A SELECT FEW WITH HEADGASKETS BLOWING AND HEADS
CRACKED BUT THEY HAVE FIXED THAT KNOW NO OTHER PROBLEMS
I KNOW OF JUST BOUGHT MY 04 2500HD CC 4X4 YESTERDAY RIDES
GREAT HOPEFULLEY LIVES UP TO EVERYTHING I HAVE HEARD ABOUT
IT GOOD LUCK I HERE FROM EVERYONE APPROX ANYWERE FROM 4-
7 MPG ON DURAMAX THAN GAS :banghead:
I have 305's on a stock hight truck with just the torsion bars installed... 17 in the city and almost 21 on the highway..I got 18mpg pulling 8000lbs to Dallas TX and back....
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
