Fog Lights that work?
Has anyone else noticed that the new Yukons, and probably their similar truck bodies, have fog lights that are pretty much useless? You can just about tell when they are on.
Does anyone know of an aftermarket replacement that locates in the factory housing that can provide real fog light usefulness?
Some people have upped the wattage in the bulbs with good results. Just don't go too far because you could melt the lense.
I know what you mean, I actually bought the kit for the Sierra and installed everything myself, I turned them on and thought &%^$# I screwed something up. But nope they are just basically decoration. They even have the higher wattage 9145 bulbs. :thumbs:
Are there very many vehicles out there that actually have really bright factory fog lights? I know I haven't exactly experienced mind-blowiung results from anything I've ever driven. The new lights on the '03 & '04 Sierra fachias are much better than the rectangular ones though... but nothing beats a good pair of HELLAs :thumbs:
I have Hella 550FF fogs on my older 'Burban and love them. My new body 'Burban has the OEM lamps and they do suck. Course, too many drivers run them all the time for decoration and so weenie is good news for the oncoming driver.
I have found that PIAA 510s will fit in the opening. I am considering pulling the factory lights out and making a similar bracket and stuffing the PIAAs in the same spot. Depending on current draw maybe the factory wire can be used. They are awfully expensive though. :thumbs:
Are y'all trying to use these fog lamps as driving lights????
As usual, I'm probably the only one who feels this way, but on my '03 Silverado, my fog lamps are the best I have ever used. We have lots of coastal fog at night in the rural parts here and these things really work well. They light up the area downward in front of you without light splash back in your eyes from the thick fog.
Out in the woods at night, they are also great for flooding the front area when you have the headlights OFF. Really handy for camping, checking fence lines after a night time storm.
Ah well.... YMMV... :thumbs:
I have found that PIAA 510s will fit in the opening. I am considering pulling the factory lights out and making a similar bracket and stuffing the PIAAs in the same spot. Depending on current draw maybe the factory wire can be used. They are awfully expensive though. :)
sWeet. :thumbs:
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
    • I'm pretty sure it doesn't actually recalibrate the speedometer it just changes the wheel speed sensor inputs to the computer. The truck still thinks it has stock tires.
    • I apologize, I missed this post, at risk of going off CURRENT TOPIC.   I'm not saying it is BS, I'm questioning how much information is being held back. GM is NOT going to spell out exactly every parameter in the algorithm. Liability, intellectual property, etc.    I'm not naive enough to believe that it is as simple as revolutions, coolant temperature, miles, time; are you?    I don't do irrational either, and boiling the OLM down to four simple values that I could code in an afternoon (I'm not a coder) is irrational - unless it suits your agenda to ignore it.
    • Chris 21 I appreciate your constructive response. !!  😉😉😉   The 6.6 is gas.  Correct me if I’m wrong but by recalibrating the speedo you’re correcting the shift points of the transmission on these trucks.?.
    • That is a huge misconception.     Bigger does not always equal safer.  Modifying does not make it safer either, with exceptions.   Think of this.  Your truck in stock form is capable of emergency maneuvers, proper stopping distances, its handling is designed around the factory wheel/tire packages, etc.   37s and a lift?  Now you've affected your braking distances, handling and ride control.  You've raised your center of gravity higher.  Your front visibility is now obstructed more than stock, same for your rear.  Does it look cooler?  Yes.  Does it now work as good as it did from factory on road?  NO.       As for my mention of exceptions?  Say you had a sedan or crossover.  They typically come with all season tires.  If you swap out for a performance all season or a summer tire, you improve your car by lowering its stopping distance (better braking because of traction) and improve the handling (regular and emergency) of the vehicle.  That is an actually improving modification.  My old 2019 LD 1500, I ran UHP all season tires on 20in wheels in a factory offered size.  It improved all aspects of how it drove over the Duratracs it came with from the factory in the stock 18" tire.
