Chevy3 Posted August 19, 2004 Posted August 19, 2004 A few months ago I had a new set of Tires installed and ever since then My S-10 Extreme started having a Drive Train Vibration. The tires where even replaced with a different set. My Local Chevy Dealership has been unable to find the cause of the vibration it's really bad around 55 MPH It's very uncomfortable to drive.... Any suggestions on what to look for or do? Thanks, Chevy3
NOS#9BIGMAC Posted August 19, 2004 Posted August 19, 2004 Are your tires balanced properly ? I've found most garages in my area don't know how to properly balance a tire. If so check your driveshaft angles this would be the next most likely source of vibration that I would check. hope that helps, good luck
Chevy3 Posted August 19, 2004 Author Posted August 19, 2004 Tires have been balanced about 4 times now. from where I bought the tires and the chevy place. chevy place has checked Transmission, Drive Shaft, Rear End. nothing is out of specs.
NOS#9BIGMAC Posted August 19, 2004 Posted August 19, 2004 not likely but your alighnment coulld be severly out of wack. also how well do you trust the techs at your dealership. I had one call to ask my roomate where he kept the key to unlock his lugnuts. (they are factory installed and are under the rear bench next to the jack) why I knew this and a certified ase mechanic didn't is beyond me But as for your problem I'm kind of stumped. um oh yeah just wondering what type of tire ,size and does it vibrate over 55mph or just at 55. my whole cab shakes like a mofo when I hit the brakes at 45 but only at 45. I know my rotors are warped but I've been procrastinating. sorry I couldn't be more help
Chevy3 Posted August 19, 2004 Author Posted August 19, 2004 The vibration is felt in the seats and the console shakes the side mirros shake. the steering wheel doesn't shake at all. I feel like it's in the rear end somewhere....
NOS#9BIGMAC Posted August 19, 2004 Posted August 19, 2004 I'm still not sure but I've got to get some sleep b4 work tonight. I'll talk with a guy I work with who used to build hot rods. He's pretty knowlagable when it comes to troubleshooting. let you know tomorrow. cya
Shadowfax Posted August 19, 2004 Posted August 19, 2004 This is a known issue on the later model S-10/Sonomas with the extended cab and the Zq8 suspension. I s your Xtreme an extended cab model? There was a detailed thread somewhere on www.s10forum.com about this, and I believe the issue was the hop shock was not tightened down, or it had to be replaced, or installed if for some reason it was not on there from the factory. Let me know if it is an extended cab model. I'll try to find that thread and see what the resolution was. Brandon
GMCSierra04 Posted August 19, 2004 Posted August 19, 2004 Have you lowered the truck at all? I could see if you did anything like that you would be changing pinion angles which can deffinetly cause driveline vibrations. You could try to take your driveshaft out an d rotate it 180* and see if that helps. Your dealership has tested the torque converter too right? Check the engine mounts, transmission mounts and all suspension components. Let us know what you find.
Chevy3 Posted August 23, 2004 Author Posted August 23, 2004 It is an Extended Cab S10-Extreme comes from the factory lowered. just strange that I've never had this problem for the first 50K miles but since I put new tires on it I have. The Chevy place says they checked everything. They have again this week, they seem to think it's a Tire or Rim
Shadowfax Posted August 24, 2004 Posted August 24, 2004 Hope you get it fixed soon. Just put 56k on my ride and have had nothing but smooth operationg out my truck. Let us know if you get it fixed and what it wasy
Envoy Fan Posted August 24, 2004 Posted August 24, 2004 Sounds like it might be a tire/rim problem. Have a repair shop do a road force balance on the Hunter GSP 9700. http://www.hunterengineering.com/pub/produ...ancer/index.htm
Chevy3 Posted August 24, 2004 Author Posted August 24, 2004 thanks, for all of the responses According to the Chevy place it's the TIRES, 2 of them are way out of road force variation I will never buy tires from JUST TIRES again... ...now I have to go argue with them... Thanks again
studly Posted August 31, 2004 Posted August 31, 2004 Wow, this sounds real familiar. I have a '98 Chevy Blazer. I had four tires replaced about three months ago and got a wheel alignment at the same time. It would give a little shimmy around 75-80 MPH. It is kind of hard to give that complaint to the tire dealer. Anyway, my tires got progressively more noisy. And, the inside of the front right showed excessive wear. I went back and they found my Blazer to be out of alignment (that's weird, they just aligned it three months ago). They realigned it and rotated my tires. They mentioned that the idler arm had some play but they don't stock the replacement part because it was only a tire dealer. Anyway, the noise continues. It is almost unbearable. I tried to pin the noise down to a particular tire by changing with the spare one tire at a time. The noise never went away. Apparently, it is more than one tire making the noise. By the way, the tires are Bridgestones. But, as I was changing the fronts, I noticed a LOT of play. I could probably move the jacked up wheel left and right by at least one degree in each direction. The tolerance is one degree; I've got at least two degrees of play. The play has got to be out of tolerance. So, I've got an appointment with a Chevy dealer on Thursday to get the play out. Hopefully, I'll start to see some improvement. We'll see.
Supurban Posted August 31, 2004 Posted August 31, 2004 If so check your driveshaft angles this would be the next most likely source of vibration that I would check. Good idea on the driveshaft check - it's quick. Just need to take out the 4 bolts front and 4 bolts rear to drop it out and check the joints. If they do not pivot smoothly, you will get a mean vibration that you can feel even just backing out of the driveway.
snuffy Posted September 1, 2004 Posted September 1, 2004 My girlfriend has a 98 2WD Jimmy and it has a bad roar in the front. Tire store says it is the hub bearings and they want $800 to do both sides. They showed her excessive play. You might have bad bearings also. She has had some vibrations when braking heavily also.
