93 oct fuel vs o2 sensors, & oil
had an interesting talk with a guy at the fuel pumps. he said a ford tech told him not to use the 93 oct fuel, it damages the O2 sensors. he'd had to have his replaced. any one ever heard this before? only difference, as long as it's not got any additives in it, is its compression pre-explosions. does the additives cause problems, like the shell stuff?
what oil brands do you all like. I've always used castrol oil 10w 30. i'm thinking of switching to senthic. I've always did 3000 mile oil changes because i live on a dirt road, well they paved it and I've been going by the oil change light (4 to 5k). I see alot of comments on the mobil oil stuff, why?
I can't imagine that the car companies would put O2 sensors in a vehicle that get hurt by 93 octane....and vise versa for the fuel companies. That guy didn't happen to have a 10 inch spoiler on his car, that gave him 100 horsepower at the wheels....did he????
I use Moble 1, and I change it out when the computer says too....usually between 4500-5500 miles.
TMF
na it looked like it was a 92 to 96 F150 4x4. figure it was a tech blaming something besides his product, but then again he may of been putting in racing gas. you never know about people.
Ahhhhhh, and there you have it. Another pony boy trying to bring down the bowtie. Dont believe those guys, they like to poison your mind with lies.
I have to say that sounds like a little bit of :thumbs: to me, but im no mechanic. Seems like those O2 sensors have a mind of thier own though. I wouldnt think it would have anything to do with the 93 octane gas however. Still, i will continue to put the SUNOCO-94 in mine....no problems here.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
