Blue Collar TV
Cool Zr2
I just laughed my butt off...
Bill E said at the end of the show something like...
There should be an application that women have to fill out on order to wear a thong.... LMAO.....
:cheers:
I think what he's trying to say is... Most girls at his school (which when you think about it is a common occurence all over the country) wear Skirts and Shorts that break the dress code at his school.
If I'm figuring correctly. he's still in high School (He turned 17 this weekend).
Hopefully I've lessened your confusion, now please help lessen mine. Why do you want to know how old he is?
I'm just curious though :D I'm not being defensive or anything. Sorry if I'm coming off that way.
I was just curious cause in my day girls didn't wear thongs in high school.
Maybe I just didn't notice.
Maybe I did.
Can't remember.
I just don't remember girls having them hanging out like you do these days.
:D
