Those ^%%^#&^% center caps
:thumbs: Okay, I have a 99 Sierra with the chrome rims and center caps. I have lost three of the four caps and have just bought four new ones off of ebay. How do they stay on? The pitiful little plastic threads do not hold onto the threaded lug nuts tight enough to keep the cap on. What do yall do? Please help.
Believe it or not, when installing those black plastic caps that screw onto the lug nuts, the lighter the touch the better. The threads strip very very easily. Just 2 or 3 clicks at the most and they're on. Don't try to torque them down real tight or the movement of the wheel will eventually make the threads round off and the cap will be gone. Especially if you drive on a lot of bumpy roads.
I find that I only tighten those by hand, take the socket and an extension and tighten them only as tight as you can make them by hand. I have always done this on our blazers and now on the trucks. Never broke, stripped or lost any yet. Sometimes less is more :thumbs: Good luck.
Same here.
You have to make sure that they click into place or they will back off even if it doesn't feel as tight as you think it should. That took care of my problems with them. For extra protection at one point I did however smear a little dab of RTV on the inside of the cap and that tightened things up but came right off the next time.
mike
Yup, that is also a concern with F-body owners, as stated previously just hand tight. This works very well and is what I do, I use the method tryn2lrn describes. On my Sierra, it is missing one center cap, guess I'll follow your lead and get them off of eBay. :fume:
