Here we go again
MCourson
Another hurricane, another power outage. Started at 2:20pm lets see if we go another 100 something hours. This time I have the modem and router hooked to the generator so at least I still have wireless DSL. :devil:
I feel your pain. Here in NC we had a fair share of them over the years. Don't wish them on anyone. No fun without power to keep the house cool and your out busting you butt cleaning up all the mess left behing and not a cold drink in site.
Hope all fare's well with anyone that has to deal with these hurricane's.
It's all about priorities...good luck
It only stayed out for about an hour, then went back off about an hour again and is back now. Half of my neighborhood has been out since the first outage so we are lucky.
Unfortunatly the generator is going to need a rebuild. Oil is passing by the rings badly and I couldn't even get it to run an hour ago. Although it didnt help that it was dark and raining. Maybe if Im lucky will be able to find a rod, rings, piston, springs, and some other stuff. Take it over to my kart engine builders shop. Get that thing line bored and prepped up, the power just went out, and get it running like new. If I was smart I would have done this after Frances when it ran for about 100 hours. Hey the pwer is back, and now its off agian. :devil:
Power is back so I can post this.
Power is out again and I cant sleep. It has been about 2 hours. I have fixed the generator enough to get us through this. Then I went for a ride and started pulling limbs out of the main roads around here. It is pitch black out there. Every so often what I guess is a transformer blowing up or something but the whole sky will turn green and it lights everything up.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
