Push button 4WD
Just curious if any K1500/K2500 owners out there have had any problems with the push button 4x4 system? I drove a 2000 K1500 over the weekend with this system and the left front hub seemed to rattle while turning. Is this common or possibly a problem on this truck? BTW, the truck only has 24k miles on it, not sure how much of those were in 4WD.
Thanks folks! :cool:
I'd say that '00 has something wrong with it... (maybe an accident or something).
The biggest problem with the pushbutton 4wd is the switch going bad. The good thing is that it is relatively inexpensive and very easy to replace.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
