help need info bad
Possible brake line extentions, might be able form existing ones to fit.
Possible transmission/transfercase brackets extentions,Steering extentions
Go online and download a set of directions. May be alittle work but worth the 3 " of lift.
Get a Performance Accessories kit. It will have everything you need. (If you want to raise the back bumper it is extra)
Steering shaft extension
modification to fan shroud
no brake line mods
some wires are moved, but I didn't have to lengthen any
gas fill neck extension
bumper relocations
It is really easy . With a buddies help you can do it in an afternoon.
