WANTED! 2 door yukon/tahoe parts
I've got some 3" diameter stainless nerf steps for a 2 door if you want it. In great shape. Only used for about 9 months. $100 plus shipping. If you're interested in a lift kit, I've got a 9 month old fabtech. We've got the same truck. Let's see pics of yours
got nerf bars now, want to look at factory running boards for a change.
what size lift is the fabtech and what is your price?
will get some pix of mine up and running soon.
thanks for your fast response!
wanted for 96 yukon gt (2dr)- prefer used parts
-oem running boards
-obs denali/escalade console
-front push bar/grill guard
-tailight guards
OEM running boards are fairly rare for a 2-door although some did have them. See them on eBay occasionally.
Denali console..you have to get extremely lucky to get one for less than $500
Grill guard and taillight guards, same as trucks.
Here's a link to my fabtech kit.
http://www.gm-trucks.com/forums/index.php?...topic=33353&hl=
And here's a pic of my truck with the kit on.
http://img.photobucket.com/albums/v179/lokoh/YukonGT.jpg
It's a 6" kit.  I also have the front differential that's modified for the fabtech kit if you're initerested.
what modification is needed for the kit? cutting? welding? etc, or, is it just bolt on?
if i may ask, why are you selling the kit?
will the kit work with the blocks, or would i have to purchase add-a-leaf?
with this lift and 35's, did you have any rubbing?
thanks-
TrooperGMC check your PM.
  Check out this link too.
http://www.gmfullsize.com/forum/showthread.php?t=13009
and this link
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=33650
lokoh-thanks for the links, i bought a set of running boards from one of those links.
i am going to pass on your suspension lift, but check this out:
http://www.gmfullsize.com/forum/showthread.php?t=12937
and this link
Yeah, he already offered me $600 for the kit. I passed on the offer.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
