No more Ford Lightning!
MyBigToy
Sounds like a good time for GM to put the Silverado SS into the RC SB category and drop the AWD. I can see it now......
2005 Chevrolet Silverado SS
Regular cab
Short box
6.0 LS2 Corvette Supercharged V8
500hp/500
6-speed manual
RWD
I'd buy one! :nono::P
If you really think about it, these sort of vehicles are almost pointless. Don't get me wrong, I would love to have one, but there are so many different vehicles that are much better for what ever purpose you use it for. I've always liked them, but I'm not suprised they dropped it.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
