tires
i'm looking at 285's in either dunlop radial rover a/t, radial rover r/v, or the pirelli scorpion a/t. any input?
Years ago my roomate from college had Dunlop Rovers as OEM on his Nissan pickup.  They lasted a long time for him...
At that point in his life he was working as a tree planter and would drive back into areas where they clear cut in the middle of the woods and plant 1000's of new trees.  He rarely got stuck, and I saw pictures of some of these logging roads and was truely amazed!!!
Goodyear, Dunlop and Kelly in passenger tires and Goodyear, Dunlop, Kelly and Steelmark in truck tires; are all related companies. While I don't have any personal experience with the Dunlops or Goodyears, from what I've read on various forums Goodyears don't wear very well. Don't know whether that would extend to Dunlops. Earlier post suggests not. My brother runs Goodyears even tho he knows of their problems but he has access to a lift & rotates his every oil change, about every 3000 miles. Problems I've read about concerned cupping & accelerated wear.
Good luck in your choice.
My dad has a set of Dunlop Rover Rv's on his '89 K1500 and you can't beat them for the money.  They are noisy though, but traction is great.
One of our forum members (Hoot) has Dunlop tires on his 2500HD.  You might send him a message asking what he thinks, since he has first hand experience with them.  I've never run a set of Dunlop tires, so I can't really comment.
Another thing to consider with tires, is wear vs traction.  Usually, when given the same tread pattern, a tire that wears faster usually has better traction and a tire that wears slower has less traction.  It just depends on whether you want more traction for tricky spots or if you want more durability and less tire changes (and probably easier to burn out with   :) )
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
