Anyone with a 4.8 or 5.3 have these?
I just got the 2004 GM performance parts catalog and noticed in the chevy "GEN III Design" section on pg 104. It has these LS6 Heads "CNC Ported" for the 4.8,5.3, and 6.0 Gen III V8. Does anybody with these motors have them and if so how much of a difference it made in performance? :D:mad::fume::(
-Mike
P.S
How more power will these give my 4.8?
Here is what im talking about. Look at the very bottom of my page. :mad:  :fume:
My Webpage
If you use them it will drop your compression. Wrong direction to go for a perfromance increase. The chambers are bigger than what are on the 5.3 heads. If you mill them, and im not sure you could mill enough off to safely get back to compression of the 5.3 heads, you could get the ratio back up. Just look for a set of stage 1 or 2 5.3 heads and go that route. That or get your heads ported, polished, blended and milled a bit. You should be really happy with the outcome of that. Most LS1 guys buy 5.3 heads and get them worked over and slap 'em on.
I just got the 2004 GM performance parts catalog and noticed in the chevy "GEN III Design" section on pg 104.  It has these LS6 Heads "CNC Ported" for the 4.8,5.3, and 6.0 Gen III V8. Does anybody with these motors have them and if so how much of a difference it made in performance? :jester:  :D  :mad:  :jester:
-Mike
P.S
How does it lower compression when it says its made for our motors? :jester:
-Mike
P.S
Bud, it is made for our motors. But you need to understand that the dome size of the heads on your 4.8 and on an LS6 are totally different. If you put heads on your 4.8 that have a smaller dome than a stock 4.8 you are going to decrease your compression. Vice versa with heads and smaller domes, the compression will go up!
You could be right, but it could also mean that the heads for the 4.8L have already been milled sufficiently to maintain or raise CR.
LS6 heads and 4.8 heads are in fact different. The 4.8 and 5.3 are 63CC chambers. Whereas the 5.7 LS1 chamber is 67cc, the LS6 is 64cc. 6.0 heads are just bigger chambered LS6 heads at 71CC's.
I get what you're saying about the differences. It's certainly possible that the description in the catalog was just a misprint...or maybe it's for real and they've already prepared the heads as necessary for each block.
Id bet they are just plain old stock LS6 heads, 317 castings. Unless they will mill them for you after purchase. But I dont think they would mill LS6 heads for evey LSx based motor out there. Thats alot of different mill specs.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
