Took the beast mudding today....
Torque Junkie
More...
In this I actually got "stuck" (had to back out) That pit is f***n DEEP! The front tires were completely submerged. But I just put it in Reverse and backed out of it.
Meisha driving the Dodge :(
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
