Raising the front
hd04
I want to raise the front so it is even w/the back is their any way of doing this w/out raising the tortion bars and would any one recomend raising the tortion bars on a 04 hd?
I was also wondering if I raise the front by 2 inches and left the rear of the truck alone would 285/75 fit?
Should be no problem, I put that size on an 04 HD GMC with the stock wheels and had to do just a little trimming on the drivers side wheel well.
I could not get aftermarket 16x8 wheels to fit without major trimming of the painted fog light dam.
if your truck is a 2wd you can get some new spindles for it, other than that if its 4wd you need the f**d keys to do it 2 inches depending if theyre maxxed out already :banghead:
