My New HD
Chevy Tough- Yeah I plan on going through the winter on the smaller tires because they are practically brand new. Hopefully I will have some money saved up so I can get some tires. I have a list of things that I would like to get for the truck. I would like to get a tool box, cab visor with lights, bug shield, either nerf bars or running borads,mud flaps,fog lights, and yeah either 265's or 285's. Do you think that I will get a little better gas milage with bigger tires and the 4.10's? That and I'm not sure as to what size to go. Thanks alot for the complements to
William
While i get 18 mpg with 265's on my 02 HD, its a basic setup like yours except if you count the bull guard i have on it, plus mines the D/A combo, but going to 265's shouldnt hurt the gas on it but if you decide to go bigger you might have to recalibrate you speedometer. The mods i have on my rig is the bull guard and roll bars, ill try to get a pic of it on here soon, i wanna drop the stock rims for some MT Rims so thats in the works.
    • Correct.  2019-2021 model years are serviced by a different p/n.  19420611.  Recall 2021s use 19420611.   The recall engines 2022-2024 model years are serviced with 12740076.     The difference between 19420611 and 12740076 is GM changed injector size for 2022.  The injectors are smaller on 12740076 with smaller injector bores in the cylinder heads to match the smaller injectors.  So you can't install a 19420611 in a 2022-2024, and you can't install a 12740076 in a 2019-2021.     Both engines are the replacement engine p/ns that are in the L87 recall.  So both of these are the updated engines.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
