Jeopardy goes PG
tmf6902
I think from Ken's smile, he knew exactly what answer Alex was looking for. Heck, he had over $14,000 and both of his opponents had negative dollars.
I don't regularly watch the show anymore, but I did watch Ken's loss. Again, I think it was intentional that he lost. Even the lady that beat him said in an interview that his opponents generally admitted to defeat before the game even started. They needed to get back to normal games or handicap Ken by putting a time delay on his button or something. Ken's going to make big bucks being brought back for special shows.
two things....
#1. 99 I completely agree....why does alex always have to throw his 2 cents in???
#2....I think he threw it too.....I know he said he always does his own taxes....but hell, that was one of the easiest final jeopardy questions they ever had.....and his answer of FedEx doesn't even make sense. I mean, is fedex even considered a white collared job? I've been watching jeopardy for way to long.....it's kinda boring with out Ken, it was fun because he actually bet big, I hate it when people get a daily double and bet like 1K....when 7 or 8 would give them the lead.
Ok total geek rant over....back to reality.
