2004 Silverado - Zerk Fittings
Nope,'04's still have zerk fittings.Thank god they didn't take them out yet :cheers:
I think they learned from the '88-'89's that it don't work to well without them.
Although the new Colorados/Canyons don't have fittings.
I believe they are all around the front suspesnion/steering components. I dont think mine has any on the driveshafts or u joints.
Nope,None on the U-joints or driveshafts.
You have the Upr. & Lwr. Ball Joints,Inr. & Otr. Tie Rod ends and the Idler & Pitman Arms(and you have to remove the skid plate to make it easier to get to those-which is why some dealers and quickie lubes don't grease them!! :cheers: )
4x4;s
You have 12 on the front suspension and 1 on the output shaft seal (it's more like a small hole in the seal on the bottom). You'll need a needle adapter if you plan on lubing this one yourself.
2wd
You get only 7 on the front.
-Ivan
I could be wrong about this (wouldn't be the first time :cheers: ) and someone correct me if I am, but I think that "small hole" your talking about isn't for grease,I think its for moisture to escape,that design seal is known as a "booted" seal and protects the shaft of the yoke going into the transfer case,the main seal is in behind the "boot" part of the seal up against the transfer case.
And I think there are only 11 fittings on these new-body-style 4x4 trucks,at least thats all that was on my '99 and on my '04. My old-body-style trucks ('93,'94 & '97 K1500's) had 12 with one being on the frt. driveshaft.
Again someone correct me if I'm wrong or part wrong :flag:
I only find 11 on my '04 too.
On 2004 Silverado's, Tahoes, and Sub, there are only 11 Zerks. Check the tech section of the board to see them all.
I just did mine about a month ago.
    needafix
    needafix
  • Who's Online   1 Member, 0 Anonymous, 587 Guests (See full list)
