any damage?
By mistake I shut off my truck while I was in reverse. When I started up the truck again in park, I thought I heard the engine start and then shut down. (kind of like a clunk sound) Not to sure because the radio was on and I couldn't exactly hear everything. Seems to be ok now, but did any damage occur?
1998 Z71 5.7L
It won't hurt anything. I've done the same thing on occasion. The clunk was probably just the transmission trying to figure out what happened once it had fluid pressure again. :ughdance:
Transmissions are easily confused little boogers aren't they. :flag:
Sorry your comment just brought a grin to my face.
Back in the day, I actually used to do that on purpose to keep some of my vehicle's engines from running on. I had alot of beaters and alot of project cars that had alot of issues at times, that would cause the vehicle to idle on when the key was turned off (base idle too high, too much timing, etc.) You've probably seen it happen in movies when there's a real beater car that's smoking and falling apart and it's shut down and goes chug-chug, pop, spurt, chug-chug, pop, spurt, chug-chug, pop, spurt....fart.
Well, by turning it off in Drive or Reverse, it would keep a load on the engine and it would shut right off instead of idling on. I wouldn't recommend this as daily practice, just in those special situations.
