FOR SALE - 1994 Chevy Silverdo
OUMike
FS - 1994 Chevy Silverado 4.3L V6
181,000 miles
Black stepside with gray split bench interior.
Pioneer Premier 740 MP3 radio with Polk 6x9s up front
Parts replaced
Alternator
batter
compressor, accumulator
radiator
front rotors
brand new BF Goodrich Land Terrains (6000 miles)
water pump about 3000 miles ago
fuel pump
fuel filter
cap and rotor
plugs and wires
tension pulley and belt
email [email protected] for pictures
Cleanest 94' you'll find. $4,000 OBO
