2001 8.1 Burning Oil
Hey guys, my 8.1 is buring 3 qrt.s of oil between changes, after a good 30 min trip, you can smell it, oh yeah, intake manifold bolts and manifold itself has done been replace 9,000 miles ago......
If you smell it there's a leak. Look for it.
Valve covers, oil filter adapter, front or rear crank seals, etc. Mine leaks a little from the front seal.
Vernon
My 01 8.1 goes through 3 qrts between oil changes---always have since new. No leaks. The dealer says it's normal. :dupe:
Yea, my buddy who is a service manager at GM dealership says the 8.1's do burn some oil. He recommends I check often. I go through about 2 Qt's between oil changes. I change oil every 5k, even if engine monitor says I'm good to go...
Man I am lucky to burn 1 qt in 5000 miles.  Isn't there a fix for this?  I read something on here about a new something to keep the 8.1 from burning oil.
New ring pack---change pistons too so you don't have that nice Diesel-like rap at startup.
What kind of oil are you running?
The last 2 oil changes its been Castrol GTX 10W-30
i tried 5w-30 before that, no diffrence...
What i dont understand is when your burning oil out the exaust pipe, you should lose alot of power, i havent, ive got alot of power! Just dont understand..........
Nope I have a very small amount of piston slap at startup....could be the real deal....could be a cold engine starting for the first time of the day. Reguardless it goes away after about a min of running. So I'm not really concerned about it.
The fix I was thinking about was the upgraded PCV valve.
TMF
tmf6902:  How many miles on your 8.1?
I've just turned 10k on mine and don't hear any piston slap *knocks on wood*
My 8.1 has almost 12K with no slap. It
does use a qt. between changes more
if I'm towing.
I went thru that on mine, their is no pcv valve on an 8.1, at least thats what 3 dealers told me, i can't find it either.....
I switched to M1 5W40 SUV blend and my consumption has seemed to lessen over the last 4K miles
This is not a scientific observation, I just don't seem to have to add oil as often
I just got the Helms 2001 CK5 service manual 5 volume set for Christmas, obviously, this is coolness. :smash: I'm learning all kinds of good stuff scanning through them.
Here's what it has to say about the PCV system on the 8.1:
"Crankcase Ventilation System Description
The crankcase ventilation system has no serviceable components so routine maintenance of the system is not required.
A closed crankcase ventilation system is used in order to provide a more complete scavenging of crankcase vapors. The air cleaner supplies the fresh air through a filter to the crankcase. The crankcase mixes the fresh air blow-by gasses. This mixture then passes through a pipe/passage located in the intake manifold."
Don't get to hung up on the part about the air cleaner supplying fresh air through a filter to the crankcase, there isn't a separate filter for the PCV system, that is refering to the engine air filter inside the air cleaner box.
I must be lucky, my 2001 8.1 @ 55K dosen't burn excessive oil or have any piston noise at start up.
Vernon
