newbie here
drfrankenstein
hello all.. i am mike.. i am new to the forum.. i purchased my tahoe from a dealer in june 04 wit 84k on it.. i live by my username.. i lie in washington dc. and i am not looking to do much modding to my truck since i have other toys to experiment with.. o and i am very experienced (for someone of my age) with vehicle repair, maintence and modification. but nobody knows everything and this is my first truck so if i ask some newbie questions.. dont mind me.. jus point me in the right direction if u dont have an answer
Welcome :cool: And ask away with any questions,someone on here will know! :seeya:
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
