4L60 shifting problems?
I have a 1992 chev 4x4 with a 4l60 tranny. here is my description. When the truck is cold it will shift hard from 1st to 2nd but all other shifts are normal, with lots of power. Howerver when the truck gets cold it shuttle shifts (it shifts really fast from 1st to 4rth) with no power. If I floor it it seems like it's slipping from gear to gear. Also, I have no downshift when I floor it. I don't know what's doing that because the transmission has been rebuilt and a new tv cable has been installed.
