Dear John Letter
MMM
You'll love this.......
The ultimate response to a Dear John Letter...You gotta love a man like
this...Humor in the face of defeat!!!
A Marine was deployed to Afghanistan.
While he was there, he received a letter from his girlfriend. In the letter
she explained that she had slept with two guys while he had been gone, and
that she wanted to break up with him...AND, that she wanted the pictures
that he had of her back.
So, the Marine did what any squared-away Marine would do. He went around to
his buddies and collected all of the unwanted photos of women that he could
find.
He then mailed about 25 pictures of women(some with clothes, some without)
to his girlfriend with the following note...
"I don't remember which one you are. Please remove your picture and send the
rest back."
In order of importance well ingrained in boot camp by a crotchety old salt DI (was that redundent?)
God :crackup:
Country :seeya:
Corps
Family
... All others
hookers :crazy:
thiefs :chevy:
cheating girl frineds :chevy:
cheating wives :cheers:
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
